All Small Six Manual to auto swap on 200ci
akidwithacar
Active member
Ok so I have a 65 mustang with a bad 200ci in it, and I have another new to me 200ci from another 65. The one that's in my car is SCV equipped and paired to a C4, but my new one is not SCV equipped and came out of a manual 3 speed. My question is what do I need to change to make the manual engine work with my auto transmission.
Hi akidwithacar. The non SCV would be a little better performing system that is if it has the correct matching Distribitor with it. If you just want a totally stock system and dont care about adding any performance than you can just swap the Auto Trans Engines Carb and Distribitor into the Manual Trans engine. So to better answer your question could you post some pictures of all those parts? You will of corse need to also remove the Pilot Bushing out of the center of the crankshaft of the Manual Trans engine, all the bell housing, flywheel and the tin engine block spacer plate. Then replacve all those items with those that are on your Auto Trans engine. Best of luck
