kirkallen143
Currently I am waiting on the E0EB-**** head, they are chasing cracks from welding the low/fill spots. What I am asking is it OK to mill the head that's on the engine now w/out doing a valve job. There are no problems with it now, and compression is good in all cylinders as I know of. I am milling the intake for the 2-barrel direct fit and then go ahead and mill .025 off the bottom to raise the CR while it is there. I am probably running 7.5 to 1 now with the Fel-pro gasket installed (D5 head, 7cc dished pistons, etc...) I will confirm the combustion chamber size of each cylinder before it goes to be on the safe side.
"Every .010 milled is approx. 2cc...every 10cc is approx. 1 number increase in the CR."
This will be on a turbo application, so 8.0 to 1 ratio max. Any responce is very much appreciated, Thank You.
Kirk ' 73 bronco
Kirk ' 73 bronco
