Mini Starter?
Crosley
I recall a discussion on mini starters for the small 6. I can not locate the threads.
There is a common Ford type 2 bolt mini starter that will bolt onto the 200cid engine with a small round bell housing?
8)
I was at a swap meet in Indianapolis last Sunday and a guy was selling mini starters. Apparently he was rebuilding the starter units and had someone making the adapter block plates.
I asked if he had a mini starter for a Ford FE motor and he wanted to know if I had a 2 bolt or 3 blot and if it was a 3 bolt were all three bolts threaded?
Im going to be using a 1967 3.03 bellhousing with a T5 adapter plate.
I got his card because I did know which one I should get.
