1968 Falcon
Long story short: my car won't start.
Long story long: I decided I would replace the starter motor on my Falcon, it still worked, but had a pretty impressive sound, sort of like it was filled with BBs. I picked up a new motorcraft one from AutoZone and installed it in my car. Before I put it in I tried the old one a couple times just to make sure everything was working, it was. Once the new one was in I tried it several times, the first 2 times it worked, but after that it did nothing. Turning the key only made the lights go dim, and the solenoid buzz/ clunk continuously, the same way it would if the battery were dead. I took the car back to AutoZone (via pop starting) and replaced my also very old solenoid with a shiny new Motorcraft one, and still when I turned the key it would only buzz. We then tried jump starting it, attaching a different battery, and ended up taking the starter out again and testing it inside. As it turned out it was completely shorted out, no movement at all. I figured that it had just been the new starter all along, and I ended up getting my rusty old one back because they didn't have any more in stock. I put my old one, that had been working, back in the car and tried starting it. But the same thing happened! The solenoid just buzzed/clunked. I took out the new solenoid and put the old one back in, restoring everything to exactly the same way it had been when the car was starting fine! Now when I turn the key the solenoid just clicks once but nothing else happens! The lights dim a tiny bit, but not as much as when the car starts normally.
What is happening here!?? I learned a long time ago that my car hates new parts because it just has its own way of doing things, I can respect that it doesn't like change, but this is stupid.
Thank you for reading my troubles.
