It's unfortunate when a project that was once going strong begins to stall and suffer setbacks. Back in Summer 2023, I took the Ford ('66 Fairlane 500) for a road trip to the coast (2hrs one way). By the time I made it home, the car clearly needed a transmission rebuild. I had been putting that off since we revived it in 2021. Progress on the restoration got slower after that. I worked on the engine briefly in May 2024 -- brazed a crack in the oil pan, replaced timing chain -- but then work stopped altogether due to the war and situation in my country.
So, the car sat for 6 months. When I tried to turn it on in December '24, the battery was a bit weak but the starter cranked at what seemed to be a normal pace. Engine would not start. Let it rest 30 seconds between tries. Cranking progressively got slower and slower. Tried jump-starting, no dice. We pulled the fuel line from the carb and found no fuel pressure. Had to roll the car back into the garage afterwards.
S'pose I was being a bit naive and optimistic by cranking like that. Figured the fuel bowl would fill up any minute but it never did. I'm hoping I didn't damage the engine.
Will definitely charge / replace the battery, and I have a replacement fuel pump. Not sure if i can source a starter locally -- will have to import it. How likely is that to be the culprit? Looking forward to hearing y'alls thoughts.
