I sent in a question to Holley a while back about multiple tbi's. Below is some cut and pastes:
So..... since the 1 bbl TBI's are no longer an option, maybe I could do the two 2 bbl TBI setup. One centered over the #2 cyl and the other centered over the #5 cyl.
But..... a new question: In multiple TBI setups, would only the TBI unit that has the IAC connected be maintaining idle operation? If the Commander 950 can only control one IAC, would the other TBI not contribute at all for idle fuel and air? If so, this would lead to a lean mixture for the cylinders beneath the non-contributing TBI and a rich mixture for the cylinders beneath the controlling TBI (the one connected to the ECU).
Am I out to lunch on this one? And would it really matter if only one contributed at idle?
Scott
Scott":1jo45m40 said:I'd like to modify my intake (it is integral to the head) to direct mount 3 holley 1 bbl TBI's or 2 holley 2 bbl TBI's. I understand that this is a custom application and that I would need to modify the intake and/or make the adapters myself. Can the Pro-Jection and/or Commander 950 ECU's control multiple throttle bodies? Can I buy the 1bbl throttle bodies (3 of them) or the 2bbl throttle bodies (2 of them) and plug them into a holley ECU? The reason I ask the last question - the 1 bbl throttle bodies are listed a an OEM replacement for GM vehicles.
What would I need to get - i.e. a custom stand alone kit?
What is the bolt pattern / base plate of the 1bbl and 2bbl throttle bodies? Do you have drawings with dimensions? I'll need this to determine how to modify the log head (also the throttle body height - for hood clearance).
Thank you,
Scott
Holley":1jo45m40 said:Hello
The commander 950 ECU will control up to 4 low impedance injectores or 8 high impedance. Unfortunately the 1bbl TBI units are no longer produced. You can run multiple T-bodies you only need TPS input and IAC for one. The over all height of the 2bbl TBI is 4.5" Unfortunately due to patent resrictions I can not provide any drawings. The bolt pattern is the same as a stock GM TBI.
Scott
