8) as to log size, the later head is going to have a large log, but it will also have a large combustion chamber. the large log will allow better airflow, and you can have the head milled to make the combustion chamber smaller. check out the compression ratio calculator at classicinlines.com to determine what your chamber size needs to be and then let the machine shop know so they can mill the head the correct amount.
since you are going to assemble the engine straight away, get yourself a really good assembly lube, royal purple has a very good one, and get yourself some really good cam lube, comp cams is probably the best imo. use the assembly everywhere except on the cam lobes, and be generous with it, you dont want a dry start to ruin your new engine.
you are going to need to prime your oil pump before you try to start the engine. there are two ways to do this, and both work nicely.
1: the old school way is to remove the pump cover and pack the gears with vaseline, then reinstall the cover. this will make sure the pump is primed before you start the engine, and the vaseline dissolves into the oil during break in and never congeals again. i have used this procedure in the past on a variety of engine with no ill effects.
2: the new school way is to take a long hex shaft, about 6-8 inches should do, and chuck it into a drill, and before you install the distributor, run the oil pump with the drill until you get oil up to the rocker arms. this will prime the whole system so that you will not have a dry start when you hit the key. this is best done with the engine in the car ready to fire when you install the distributor.
as i said either way works nicely, and it which you use would depend on how long it will be before the engine goes into the car.
