well here are a couple pics of my head I am working on. I need to weld up a hole and redrill it (was too close to an existing hole) then it needs to hit the shop for a rebuild. hoping to get it finished up this spring or early summer sometime. it is drilled for a weber carb pattern so that a 5200 can be directly bolted on it or I cna use a common weber-holley plate to put my 7448 on it. the opening is just a hair larger than the secondary bore on the 5200 gasket.
http://img.photobucket.com/albums/v701/ ... CF0044.jpg
http://img.photobucket.com/albums/v701/ ... CF0043.jpg
