Mr Comet
Here's the first build link
viewtopic.php?f=1&t=70135
I was going to follow the first build instructions but have a few questions in regards since I am days away from becoming a grampa. Just got the block back from the machine shop (different block code C8) After doing the cleaning of the block per rbohm's instructions can I apply wd40 to the walls of the cylinders just in case I need to drop the project for a week or so because of the baby but get back to it after the baby arrives? Also painting the block clear to get a antique cast look. The vendor gave me a bottle of Clevite assembly lube and I have some COMP assembly lube from the first build. Any problem with using the clevite lube for all bearings since all my bearings are clevite and the COMP lube for everything else? Mixing lubes? Will rubber hose on the end of the piston bolts prevent all metal contact with the cylinder walls during installation? I don't want to get too anal but do want to do a good job. Thanks Denny
