Felpro oil pan gasket set.
Make sure the oil pan bolt holes are not dimpled. To fix that you need to flatten them from the oil pan mating surface with a hammer.
I use grey permatex at all four corners where the rubber seals meet the cork gaskets.
Bolt the pan down & if the above is done correctly you will be leak free.
I clamped the edge between two pieces of 1x2. It doesn't deform the dimple at the holes and gets you a straight edge. You can saw it off for the ends of the pan. The other thing is to put it upside down on a piece of plywood to get a flat surface so the lip isn't twisted out of flat. And gasket sealer.
