Some of these are already stock: the DII system specs .050" for the plug gap, using the heat range 42 plugs (that's '82' for Autolite, '5' for NGK, etc.). I've already found that the Bosch plugs do worse than the others: so far the plain Autolites are the best. I also tried the SplitFire, and platinum versions of all of the above. I found no difference with the platinums. However, the fine-wire tips (some of which are also platinum) do allow larger plug gaps because the voltage density is higher on the smaller tips. They will also jump further because of the higher concentration: this generates a stronger plasma envelope. However, I found the fine-wire tips foul easier following hot-soaking in the summer, and they take longer to clean themselves up again.
Does the Mileage Master coil run OK with the Duraspark II?
After I pass the 2004 emission test, I can switch carbs. I've long planned on using the H/W 2-stage for just this reason: better efficiency on the primary side. Can't do it just yet, though.
