i have a dead spot that i cant get rid of when i accelerate..the dead spot isn't there if i slooowly acellerate and is fine to gun it after about 25 MPH...just got a few questions n stuff...well i have a carter YFA carb...i have the EGR blocked off with a plate..its good...everything is sealed and no vacuum leaks...but there is a small screw which i think adjusts the acellerator pump/power valve or something like that...i heard that to keep the engine from running rich when the EGR normally kicks in i could just untwist the screw which would make the shot of gas from the pump be slightly delayed so it doesnt run so rich at that spot...well i untwisted it 2 turns...i havent really paid attention to whether or not it made any difference so i'm not sure if its causing any problems...i also have my vacuum advance hooked up to full manifold vacuum...i like it..but heard that it causes a stumble...could this be my problem? i installed the MSD 2 Blaster coil today hoping that would solve a bit...but nope...runs better though...but i really hate the dead spot...especially since i cant race or anything like that...i can barely do a burnout...feels like i almost kill the car...no overwhelming smell of gas...but i do need to have the air mixture screw out quite far...any reasons why this is...does this result in richer or leaner fuel mixture at idle? i am happy with the way it runs except for the dead spot....thanks in advance
