JMB":109q8wd2 said:
But, aside from which distributor I have, I was thinking of using the DUI distributor from Classic Inlines with the New Autolite 1100 Vaporizer because the discription of the DUI disrtibutor said that dyno testing showed a 20 hp increase by doing this alone. Does anyone know if this Carb with this DUI distributor will work good?
I can't speak to specific compatability with DUI, but I'm running a Mallory DP with centrifugal/mechanical advance only. As you should be able to see in the photobucket pic (should be able to enlarge for better detail), I've plugged the SCV vacum source on my carb (note little brass plug with teflon tape). I have not had the 1100V hooked up long, but she is
silky smooth, power is good. I think DUI requires manifold vacum source off intake, but please DO NOT quote me on this.
I had read that using a non-SCV dizzy with an SCV carb could be an issue (non-SCV won't work with SCV vacum source), or that plugging/capping the scv to dizzy port (brass plug) could be an issue (create internal vacum leak). I have had no issues so far with the new carb except the smoothest idle I've had in 20+ years. Unfortunatley I can't give any stats as yet since I don't know how accurate my speedo is (need to check with GPS) and am trying to change the rear end soon which will change gearing again.
I did not tell John at Pony exactly how my ignition was set up. I requested a stock set up for load-O. Based on others comments and some on my experience, John @ Pony is not really keen on mod apps although Mike and others work with him on the dyno earlier this year maybe changing his mind (see posts). Point being, if you're purchasing a V1100 and want support/help with future mods I woud think it is better to go through Classic Inlines (same price on V1100 as Pony Carbs last I saw).
NOTE: Some past posts have suggested using epoxy down in the passages behind where I placed my plug to close the port. I did not want to do this in case I found it necessary to go back to a Load-O with Petronix, but it is more likely I'm going to DUI in the future.
