Not sure if I have a problem or not. What I have is that if the motor sit's for a while like a day or 2, when I go to turn it over, by hand, it takes a fair bit of effort. I have to use a 1/2" breaker bar wedged between 2 flywheel bolts threaded into the crank. I'd guestimate ~100lbs of pressure maybe more. Then once it's turned at all I can turn it with the balancer bolt no problem, I measured the effort @ around 35lbs with my torque wrench. But if it sit's for 5-10 minutes it goes back up to around 75-80lbs to budge it again then back to 35lbs. I can't feel or notice any point in it's rotation that is tighter or looser when spun around steady by hand. I used assembly lube on all bearings, plastigaged all bearings and they were right on the low end of spec. Threads all give a light coat of light weight oil. The cylinders have a light coat of 30wt and the pistons with rings were dipped in 30wt before they were installed The head is off the short block is complete, motor is still on the stand. It's been sitting for a while, few months and I've notice a fair bit of assembly lube drip out of it. Also, I re-torqued the rod nuts and dbl checked the main bolts before I installed the oil pump and oil pan. I had to re-torque the rod caps or properly torque them b/c my torque wrench was at work when I installed the pistons so I was careful to lightly torque them until I got my wrench home.
Am I being paranoid or should I pull the pan and dbl check the rod caps? Also, 25lbs of tq on the rod caps doesn't really seem like the bolt is getting much stretch, but that's the spec right? I torqued to 25lbs then 1/8-1/4 turn more.
