Well, we finally decided on a new dizzy manufacturer. Any of you had any experience with Performance Distributors or DUI units? They already make a dizzy for the big six. I met with them at the PRI show and worked out the details to produce one for the small sixes for FSPP.
It will be a simple one piece, drop in unit, with the coil is inside the cap and the module inside the distributor. Just run one 12 volt hot wire to the distributor and you're ready to run! There will also be an optional tach hook-up included. The Street/Strip D.U.I. unit will be built with a 50,000 volt coil that allows a whopping .055" plug gap to be run. The Dyna Module is designed with more electronic dwell time producing a hotter spark. No ballast resistors are used.
Although it is uniquely designed, replacement parts will be easy to find. High Energy Ignition (H.E.I.) replacement parts will fit right on the D.U.I. dizzy. You will be able to order DUI parts and custom curve kits form me as well. The unit is polished and lubed as it is assembled and built for durability. The dizzy will also have an upper and lower bushings, unlike stock Ford distributors with only one bushing.
Caps will be offered in Blue and Black, with custom LiveWire kits in matching colors. The dizzys can be custom curved based on your specific needs, or for immediate delivery at a discounted prices, we will stock three or four different pre-curved units based on the most popular setups.
For more info on their products, visit their website.
http://www.performancedistributors.com/
Things just keep getting better by the day.
