Gene Fiore
I know it has been a long time coming, but my motor rebuild is about complete. Just a little more tuning with the camshaft degreeing to get it where I want it and just finish assembly of the head. I have been a little worried about my final compression ratio and would like someone to verify my numbers. I used a program from a website to calculate the compression based on these numbers.
Bore size 3.72
Stroke length 3.91
Head gasket bore diameter 3.80
Compressed head gasket thickness .053 ( Corteco gasket )
combustion chamber cc's 55 ( log head modified to accept Holley 2 bbl carb and some minor porting, plus 1.75/1.50 valves )
piston dish volume 1.5 ( these are 255 V8 pistons which according to the specs online the 4 tiny valve reliefs measure up to this volume )
Piston deck clearance .027 down in the hole
This is a 250 motor which has been bored .040 and will be running the Clay Smith 278 solid lifter cam.
I'm not going to say what compression ratio I came up with until I get some numbers from you all. Any help would be greatly appreciated. Thanks!
Bore size 3.72
Stroke length 3.91
