Mercury Mike
So..... she runs! Perfectly! Small miss, but I will diagnose tomorrow. I hooked up my tach. She's idling at 700 rpm, and she sounds sweet. My kickdown isn't connected at the moment, but I will fix that later. I need to lengthen the cable to work with the autolite 1100. I pulled the carb off, pulled it apart, sat down with my shop manual, and reset the 1100 to factory specs exactly. I don't use the choke though, CA's nice like that. I let her warm up after I got it started, and I adjusted the mixture so that it was nice, and then used the fast idle to get it up to 700 rpm and at 700 she runs beautifully. Should I set the idle in park or drive? And what's a good RPM to shoot for? I don't have a vac gauge so I can't really check vaccum. Shifts into drive sweet, the shifts are nice and firm like always... it was so great to get back into the drivers seat of my 'Stang! Thanks for all your help guys. I will post my next problem, and hopefully be able to give some insight to some other people! =)
