Newbie here looking for more power
Howdy everyone, I'm new to this forum and I have got to say im impressed. I never knew these little ford I6's had such a following. One of my first cars was a 74 mav with the 200 and it was probably one of the best cars i've ever had. I have recently picked up a sweet 66 bronco that has the 170 in it. I am looking for more power and I know a V8 swap is simple but, thats just not cool. it is my daily driver and I want to be able to 4 wheel and possibly surprise some of the assorted junk that litters our highways. any suggestions? My goal is to find a 200 to build up. but, I'm in Anchorage, Alaska and parts are sometimes hard to come by. If anyone out there is in the Anchorage area and has a 200 they would like to get rid of i'm definitley interested. Any suggestions are greatly appreciated and thanks in advance for your replies
Welcome to the board broncman.
For power you should pay most attention to making your 200 to be breath well. This means, you should concentrate around the cylinder head.
You don't want to use an early style head. Being in AK, you shouldn't be too specific on what you should build with, but deffinitely find what we call a "big log" head. 170s, 200s, and 250 engines are all suitable donors. Anything after 1970 will be great with a little work. Basically, the casting number should start with a "D" (1970's decade) or an "E" (1980's decade). Casting numbers that start with a "C" are "small log" heads (referrring to the intake log).
Find a good head.
- Have it cleaned and checked first. Do a little pocket porting in the valve pockets. Next, modify the intake to accept a Holley 2bbl or a Weber 2bbl directly to the intake. Have a valve job done (request a 3 angle job). Talk to your machinist about milling the head in order to get a Compression ratio in the area of 9.2:1 He will need to have a block to check specs on at the same time.
Go with a 260H cam from Comp Cams or a similar grind from fordsixparts.com Install adjustable rocker arms (rollers are also available from fordsixparts.com). Use a Duraspark II distributor (from any '76 or later 200 or 250 engine). You can use a generic GM 4 pin module for spark. Slap on a set of headers if you can fit them in the budget.
You'll have a good size increase in power over that little 170 and have plenty of torque for running in 4WD off road.
Feel free to use the search engine and poke around on this site. Lot's of cool setups, and there are alot of ways to fit a 2bbl to the manifold. Avoid use of an adapter at all costs (especially since you are builing from scratch).
You might also consider purchasing a copy of the "Falcon Six Performance Handbook" by the Schjedahl Bros. They may give you some other ideas you may want to explor.
All that said, you might think about using a 250 engine over a 200. The 200 is a direct swap for the 170, but the 250 should go without too much more work. In the end, with all the same work, you should have an extra 40 ft/lbs (+ or -) of torque with the 250 engine vs a 200.
images
Oooppps, been more than a day...Consider yourself...hoooked!!!!!
Welcome to such an international place. Couldn't just sit back because xtaxi just hypnotized you with a pic of Donald Duck in Finnish...
believe it when they say you'll get hooked, signed up, signed on, and can't seem to stay away, but lovin every minute. :D
