I have an oil leak, I believe its coming from my oil pan gasket, It may even be leaking from my rear main seal. It used to be a slight leak...like a few drips after driving it for a while, now its leaking pretty bad, put it this way, it will make a nice puddle on the ground. I want to replace the oil pan gasket but it goes right over my suspension and subframe. I here pulling the engine is the best way to replace the gasket but I simply dont have enough time as of now to do so, So my question is, do you think its a good idea to pour that goopy oil leak sealing substance in my oil? I need to stop the leak, or slow it down until I get enough time to make the actual repair? Anynone ever use that oil leak stop stuff? Let me know guys. thanks kevin.
