19Mustang65
Hi, new to the site and requesting a bit of advice. rebuilt my 66 200, runs very good, except for oil leak.
seems that the rubber seal with the gasket set would not seal in any way, tried two of them and indexed them 8:00 oclock 2:00 oclock. I removed pan and dropped the crank low enough to replace rear main with rope seal, still leaks a little, but way better than before. I have replaced the cam plug in the rear of the block and resealed the oil gally plug. I also sealed the flywheel and flywheel bolts and the rear main cap. Anyone have any ideas? would appreciate input from ya-all, :thanks:Jim
