on my '66 mustang....all the way to the left at hot curb idle, 1/3 gauge at 60 mph.
a reliable mechanical gauge shows 39 lbs in "drive" at curb idle of 650 rpm, 50 lbs at 1500 rpm. these numbers are from a fresh oil change, 15w40 oil, frahm ph8a oil filter, engine fully warmed up, relative to outside temperature of 72 degrees. i believe these figures are within specs for the 200 engine?
3000 miles on rebuilt long block.
i have tried 3 different sending units with very small variations between them.
is is possible to calibrate the factory ford oil pressure gauge to read higher?
