I commute with my 200" falcon 50 miles each way every day. it is a stock 68 with a pertronics ignition. running .050 plug gap and ignition advanced to the edge. it will ping on the steeper hills at 70 if i get into it.
what i notice is a drop in oil pressure at sustained running at 70. the gauge will drop back to 20. if i slow to 65 for a couple minutes the oil pressure will always come back up to 40. I do not know what this means.
also i note that when i am running fast in that low pressure mode, if i back off the throttle the oil pressure gauge drops even further. then picks back up. the oil pressure light comes on for a couple seconds.
also on hards stops, at anytime, i gat get the oil pressure light to come on and the gauge drops to zero for a couple seconds.
This engine is running very well, however i would like to understand what is going on if any body understands these phenominae.
I feel pertty comfortable since I know what is inside the engine. new mains and rod berings and new oil pump.
i do know the shape of the oil pan, the location of the oil pump in the front and all is conducive to shloshing the oil forward on hard stops.
also it seems that i am also reading the oil filter bypass valve at times as it seems to vary with filters and possibly with oil.
I am running valvoline durablend 20/50 which is a synthetic blend. i am running this heavy oil due to bad seals; it seems to hold oil longer.
do you think i am actually exceeding the thermal capacity of the oil and overheating the oil when the pressure is dropping at 70?
can anyone shed any light on this? and or have any suggestions
thanks frankie
thanks frankie
