original thickness head gaskets
ochretoe
Is there anyone still selling the original metal shim head gaskets or anything close to that thickness? From what I understand the Cortico 38 is not out yet. Thanks for the info.
ochretoe":3cteut0h said:
kirkallen143":3cteut0h said:
0.020" compressed, metal shim head gasket.
I guess that is the original thickness??? Anyone know if they are still available?
The steel "Shim" gaskets are available NOS from various sources but only fit the 144/170. Steel shim gaskets for the 200/250 bore size are AFAIK - Unobtanium. Occasionally the "C9xx" .037 compressed thickness gaskets show up on e-buy or on this site for sale.
Powerband 8)
I have one! I tore an engine down this weekend, and it had standard pistons, bearings, original crank/cam, metal shim head gasket, no exhaust gasket, and the original exhaust clamps on the bolts. It was amazing! =)
It may very well be possible to re-use a steel shim gasket. With a good coat of copper-sealer, it could be attempted.
I haven't tried it yet, but thought about it and had a discussion with machinist about it right after I trashed one from an unmolested 250 - DOHHHH....
If anyone has a used one I'd be interested.
Powrband 8)
Just as a point of interest....the '82 200 I recently tore down had its original steel shim gasket intact. I mic'd it at .015" (!) which really surprised me. I saved it for possible future re-use since my setup is zero-decked (actually .006" out of the hole) and .009" quench would be pushing it even for me,lol. :lol:
Terry
Hey Terry, do you think rod stretch at higher RPM is an issue with these motors?
I'd bet that rod stretch does occur but not to a great extent....less than .005" would be my guess. That is purely a guess too as I have no proof but my experiences with various engine builds to base my opinion on. I do know that the piston will grow several thousandths in height with the heat of full throttle operation-I've heated pistons and measured compression distance and observed .010-.015" growth in some cases.
My gut tells me that I could get away with .025" quench distance if bearing and skirt to wall clearances are correct. When I swap blocks in the Falcon in the next month or two (to make the T5 swap easier and to use the 10.5" clutch) I will have about .035" quench. Since I have no detonation now I want to push it a bit further to see what I can get away with.
Have you ever heard what the stretch amounts for alum rods at rpm might be? I've never seen a published number-just recommendations to increase quench clearance to accommodate them.
Terry
If I remember correctly someone here bought a few of them. he might part with one $$ :wink:
it might of been falconfreak. i'm not sure if they were for a 144 or 200. Do a search and see what comes up.
Does10s":1vx02c4d said:
I far as I know.....nope!
How about copper? I know they can easily make one down to .022" thick.
Ask for Mordy. He already has the program ready.
www.headgasket.com
Will
How about a possible group buy to offset the cost of the setup? Anyone interested?
don
www.headgasket.com
Will
If they are good for daily drivers I would be in for two on a mass buy so long as they arn't outragous in price.
don
Powrband 8)
I had 1, didn't look too bad, but I threw it out, thinking that all head gaskets can not be reused. my teacher ( I'm rebuilding the engine in my auto class ) kept calling it a Printo- Seal gasket. engine was rebuilt b4, the gasket had a red sealing bead, that looked like a factory sealing bead and not red sealer
I have two....both from 1982 engines.
I have reused steel shim head gaskets on other engines but not a 170-200-250
"It may very well be possible to re-use a steel shim gasket. With a good coat of copper-sealer, it could be attempted.
If anyone has a used one I'd be interested."
i was helping my grandfather work on his 49 ford pick-up(it had blown a head gasket) he went into his garage and came out with a used copper head gasket and a spray can of high heat engine paint,he sprayed both sides of the gasket with a good coat and put it together and ita been running good ever since and that was 3 years ago,you might be able to do that with a steel one
