xzerokidx
jlopes":1ccsfdy8 said:I have enough for the following:
Spintech muffler
The sound of the spintechs on the six sounds really good, Best choice.Maybe a little biased but, I Love mine.
Spintech muffler
I wish I could, Very Jealousjlopes":2kxj35ey said:Here is the plan for the engine:
CI Head and Intake Manifold. Street/strip port
Nice upgrade, you thinking true dual or a x-pipe in there?jlopes":2kxj35ey said:CI Headers
Don't know much aobut 4bbl... maybe it's the same as my 1bbl-x4!jlopes":2kxj35ey said:Autolite 4100 1.08 carb
What compresion ratio are you aiming for? IIRC, high CR helps mpg and HP, IDK what low CR would do except give the oportunity to use a blowerjlopes":2kxj35ey said:zero deck block
new pistons
jlopes":2kxj35ey said:arp bolts
what ever it is, advancing the cam an extra 2* will lower the rpm range of the cam as mentionedjlopes":2kxj35ey said:cam : 1.08 lob separation, not sure on the profile yet. I am more interested in bottom end torque than top end.
the 1.6 rockers will give a .480 lift on the .450 cams, be careful on lift and don't go over .500, that's when the valve will hit the pistonjlopes":2kxj35ey said:rocker arm: 1.6 ratio: don't know whether to do roller tip or not
helps in adding advance, and it's a great precaution.jlopes":2kxj35ey said:double roller timing chain
what size valves? because of the CI head, you can run the largest he has to offer :mrgreen: 1.84 intake and 1.56 exhaustjlopes":2kxj35ey said:Is there anything I am missing?
MPGmustang":uf97t0c2 said:...what size valves? because of the CI head, you can run the largest he has to offer :mrgreen: 1.84 intake and 1.56 exhaust
More Air in lower RPM's help torque, and bigger valves give more air...
Bigger isn't always better. From what I've read, using intake valves that are larger than necessary can make the air/fuel charge travel slower at lower RPM's and hurt low-end torque.
...Maybe I should get another block so I can drive the car while the engine is being rebuilt. I plan on doing most of the work myself so having another block will allow me to take my time. What do 200 block go for now a days?
Funny, the planning and building is almost exciting as driving.
Installing a cam, however, revealed all of the inherent weaknesses in my worn out engine. I could never get it to run right and the old rings took a dump on me.
Would you think installing the 1.6 rockers arms without the new cam cause problems? Just me a little more umpf until I save enough the the Al head and bottom end rebuild.
Whats the best muffler configuration? I was at a car show this weekend and the majority of the mustangs were offset in and center out, however they were all V8's.
bubba22349":1ixoh3wd said:Would you think installing the 1.6 rockers arms without the new cam cause problems? Just me a little more umpf until I save enough the the Al head and bottom end rebuild.
It won't cause any problemsthough if it will help you much is also another question
