slowhoon
Active member
Hi guys,
Does anyone know if the points, rotor arm and condenser are compatible between the pre-crossflow and early crossflow distributors?
For example, an XA Falcon might have a Bosch distributor with 9230062608 stamped on the side along with ARD10E-12100-C (or something similar) and it would therefore use the following Bosch parts:
Rotor Arm - GB502
Points (Contact set) - GB534
Condenser - GB530
On the other hand I'd expect an XC Falcon to have a Bosch distributor with a shorter body (to fit under the inlet manifold) and have a code on the side starting 74DA - but are the parts listed above the same for this distributor?
Thanks in advance,
Alan.
Rotor Arm - GB502
Condenser - GB530
Thanks in advance,
Alan.
