Have a fresh build with the CI 2100 adapter plate attached to the intake. I PCV I believe should go to the hole in the manifold , or in the hole in the adapter plate, but what about the breather cap. This is a 78 head with the PCV in the rear, fill cap in the front. Will need to find a new air cleaner for these 2100 setup eventually but the fill cap has a hose connection on it which I would think went to the air cleaner. In trying to make sure the PCV system works correctly do I need to worry about that connection on the fill cap ?
