I am just a bit neurotic about paying more for less. There seem to be two main choices in 2 into 1 adapters for the Webers (Holley, 32/36, and 38s). The cheapest adapter seems to be the one from Stovebolt, at $15. The Clifford unit is 3 or 4 times the price. The main advantage to clifford seems to be the ability to connect the PCV hose in a nearly stock position.
Stovebolt's, on the other hand, has no provision for connecting the PCV. I intially connected my PCV to the single port in the manifold, using a "Tee". The idle was horrrible, and the vacuum reading was around 5" Hg. I then drilled and tapped the adapter for a barb fitting. It runs much better with the PCV hooked to the carb adapter, instead of the manifold. I'll take vacuum readings at the two spots later. Just something to ponder for those who have hooked their PCVs directly to manifold vacuum, specially if mthey are also using that port for the dizzy's vacuum advance. I don't even want to talk hypothetical issues. Just, as Nike says, "Do It!" Or the old Alka Seltzer commercial, "try it. You'll like it!"
I have the "J" shaped tube that goes around the front hooked up as originally, and "T" in for the Cruise Control. The Power Brake Booster hose goes toward the rear using an elbow into the "T".
