chopperman69
I've got a '64 Econoline that I attempted to install a Pertronix on last night.  It's the 1/4" drive distributor.  This van was running fine before the install.
The install went smooth and when I tried to start the motor the first time, it acted like either I had crossed plug wires or the timing was WAY off. Since I didn't pull any plug wires during the install I started with the timing. Eventually I got it where it would idle, but every time I tried to give it gas, it would cough and die. Long story short, I installed a new set of points this morning and the van ran fine.
I called Pertronix this morning for some help and they first thought it was low voltage and recommended I try the power from the battery. Sorry, tried that last night. Then they thought it was (maybe) a bad ground. If you've ever worked on an Econoline (inside the doghouse) you know why I'm so reluctant to attempt this install again... If it was a Falcon or Mustang, I would jump right back in there.
Did I miss something? Has anyone seen this problem before? I really don't want to keep running points...
Right now the DUI is looking real good even though I would have to modify the doghouse for it to clear...
Thanks
Scot in OKC
Thanks
Scot in OKC
