Please Help With a Carb ID
Look like 1904 Carbs to me. Mine has a glass bowl and the other style air cleaner mount. That looks like a good matched set to start with. You gave no details as to what year and dist setup you have. Do some homework as to the usability of these units, especially if you have the L-O-M dist.
Fred
they would be going on a 65 mustang with a 200. I would be changing out to duraspark before or while I had the head work done for the tripower. I would also most likely rebuild the bottom end while I had the head off and change cams
