Howdy All:
Did anyone else notice the photo in the article entitled, "Build Your First Performance Engine", in the July 2006 issue of CAR CRAFT?
The photo is on page 53. Rather than a one piece torque plate, JMS Racing Engines has come up with an alternative to the expensive-to-build-to-use-rarely torque plate. The caption says,
"The machine shop you use should apply head-bolt torque to the block when it is being bored. Since the procedure is about the torque on the bolt- not the torque on the plate itself, JMS came up with torque bushings that simulate the stress head bolts put on the block. If you don't do this, the cylinder will distort and the rings will wear causing a shiny spot to appear on the cylinder wall near the bolt location. This is especially troublesome on the 400, where the bolt hole is so close to the cylinder wall."
I'm particularly interested in this method because of torque distortion on the thin wall casting on our sixes, the cost of making a torque plate and the outcome of more accurate machining.
The shims JMS is using appear to be a piece of steel pipe about an inch and a half long. The length will have to replicate the thickness of the head at each bolt hole. THe inner diameter is unknown, but the OD appears to be about an inch. I will be contacting JMS to see what pipe material they are using to make the shims. I hope they are good at sharing info.
Anyone about to build a short block should certainly take a look at this idea.
