When I first decided to build a 300 with a turbo, my thoughts were that the 300 has great bottom-end torque but not much up top. The turbo would kick in when the engine was out of its original power band and I'd have the best of both worlds, bottom end and top end.
Then, I found a ported head with big valves and it should support high rates of flow for the turbo.
But, will it lose the original bottom end? Is this engine naturally torquey down low because of its original head design with small valves? Will making it flow for a turbo cancel out the original advantages?
Thoughts?
Thanks in advance.
Thoughts?
Thanks in advance.
