66 E100 Pickup
ok here is the situation. This is after removing the points dizzy from my '69 200 engine.
I've got a new DSII dizzy.
Used 12 volt coil.
Used OEM blue grommet module.
I've got parts of the OEM wiring harness--horsehoe coil and 3 prong plug at dizzy. The other connections are good quality spade plug types with soldered connections.
I followed the wiring diagrams carefully, even checking with my wife to make sure I had the colors correct
When I give juice to the coil/module (engine not spinning) red wire, I get continual high volt spark shooting out of the coil tower.
When I disconnect the green wire between the module and coil, I no longer get sparking. So I got something going on with the green wire output from the module.
When I disconnect the dizzy plug, I also do not get sparking from the coil. So there is a trigger being given by the stator, evidently, to fire continuously. My black ground wire to the dizzy is properly grounded, the orange and purple wires to the stator are properly connected through the 3 prong plug.
I am thinking that the stator (brand new) is not working right. Just to make sure I wasn't for some reason sitting on a 'fire' spot, I bumped the engine to a different spot. Same results.
The white wire is not yet hooked up.
Anyone got ideas? Maybe a bad module, even though it does not send a fire signal with the dizzy disconnected?
Used 12 volt coil.
