In my HW5200, the progression hole is too far above the throttle plate at idle, so that as I crack the throttle open it goes WAY lean (like 20-25 AFR), then a little more throttle opening and it picks up and works fine.
It's *just* above idle, like at maybe 800 rpm. As far as driveability, it's just at that point where I'm just rolling along in first, like in a parking lot - and it starts bucking/surging.
As far as I can tell, the throttle plate is centered in the bore - you can see equal amounts of light all the way around it as it closes, and it'll close completely off without binding.
The progression hole seems to be just a bit too high, like maybe 1/8 of an inch. I think it's too high to bevel the lower edge of the throttle plate like the Weber book says.
My question is: Can I drill or file the hole downwards without screwing it up?
