Question about the Ford Six Handbook????
I was reading the part about the part inbetween the carb and the manifold. In the book it says that i may not need that part at all. I would love to get rid of it if it is not needed, but I have a hose that is attached to it and goes to the block. The other tube I'm getting rid of cause I am changing over to a non vacuum fuel pump. With the parts that are attched what do I do with them. What is the purpose of the part between the carb and the monifold. (cant remember the name of it.) Any thoughts or things you nice folks have done would help out alot. Thank you very much...Jake
I think the part you are talking about is the spacer between the head and the carb. The hoses bring warm water from the radiator through the carb spacer to the heater core. I'm not sure what other lines you are talking about. I don't know why you want to get rid of the carb spacer, if you are in a warm climate you can probably get away with it just fine. I don't know of a vacuum line to my fuel pump, I think mine just has fuel lines going to it.
-Dan in Jensen Beach, FL
You can mount the carb on the plate and leave the heater hoses off. A lot of guys do this. If you leave the plate off, don't get rid of it. I have seen them in catalogues for up to and over $100.
Howdy All:
The carb spacer/adapter plate served several functions from '60 to '69. I was a hot water heater to help carb warm up and prevent carb icing, it was the pivot point for some mechanical linkages, and it provided taps for several vacuum functions. The critical use is to orient a variety of carbs. You will not that the mounting studs on the log, do not match the orientation of the stud holes on the carb. This allowed FoMoCo to change carbs without changing the head castings. You will need to retain the spacer plate for correct carb orientation.
On the heater hose that passes to and through the adapter plate and then on to the heater behind the firewall, being in mild So Cal, you can do without the extra heat. I seem to recall that you have a manual choke too.(?) So you can disconnect the hoses front and back and reconnect with a section of pipe and some hose clamps. Check the coolant level and refill, as necessary.
Please note that while removing the hot water from the carb base you may gain a little in performance. You may lose a little in economy and efficiency of carb warm up. The proximity of the center exhaust ports directly below the carb make this a minor issue in all but the coldest climates.
Thanks to all that wrote back. Yes it is an man choke. Yes it is a pivot for my linkage. I have been trign to do some upgrades from the handbook. I'm putting in an electronic ignition (pertronix) and new coil I am taking the old fuel pump out that i found out after it had a lot os sludge and metal shaving inside. The new fuel pump has no vacuum crap at all, one inlet and one outlet. The other line i was talking about from the spacer is the vacuum line for the furl pump and wipers. Anyway i'll be sautering that stuff up at the spacer since it no long needed. I have also looked for another carb like it says in the book if u ave a 144 get one froma 170. It is so hard to find a single barrel carb, and i've been having troubles finding a air filter (chrome) that fits atop the single barrel. Anyway i love the book and reread it often and tring to upgrade small areas. Take care all and thanks for all the help. Jake
