QUESTIONS ON 200 REBUILD
tikitime
i have read that the 264/274 works great on on these heads but am concerend with my bone stock tranny and 67 mustang rearend it might not work well ive emailed inlines a coupeL days ago but havent heard back yet I also hear there headers are a great fit can only afford the stainless though , now the push rods will they be the right size i mean with the head work and decking will this cause a problem? I know its alot of questions but im spending 3000.00 on the motor dont want to screw up and tell my wife oh well ha ha
The 67 Mustangs have the C4 with a select shift valve body is a very good trans if its still shifting good and the fluid still is nice bright red should be in good condition. :hmmm: If you want to help it some more I all ways add a shift kit to them and a trans cooler in series with the stock one in Rad. Even for a stock engine all you will need to be good to go. :nod: What rear gear ratio do you have check the door tag? A 3:0 is ok or even better is the 3:20. :thumbup:
I agree with Bubba, a c4 trans is very strong as long as the it's reguarly checked, the tranny cooler does help, I used to have one and never used the rad cooler. i deffinetly recommend one if you have AC.
the rear end sure sure is 'weak' but most of the time it's refrenced weak only because it's one wheel driven, i think these rear ends are just fine as a daily driver, but if your wife is worried, you can say your upgrading the brakes on the car and go for a 8inch and with disk brakes upfront... :D
If the Question refers to drivability , then its a Don't , unless you put in a higher stall converter., the C-4 is a great trans and strength is not an issue , what is at issue IS low end torque , and unless you bump up the compression , increase the displacement , or put a looser converter in the car it will BE A DOG , from a dead stop , keep a stock or as close to stock cam as you can if low end is important , this is not a 300 + cubic inch engine , so unless its a stick application it will suffer without other mods, it can be a great combo with a cam added , but automatic cars and small displacement require much more than a cam swap !!!
what stall converter would you sugest for a 264/274 cam??? and is something i can do at home also the cost for one thanks !!
Easy to install , The cam your talking about would raise the rpm range aprox 1000-1500 rpm's , for as good or better than stock low rpm performance the converter should FLASH stall at least 1000 rpm's into the operating range , that would equate to a 2500-3000 rpm Flash stall rating , and yes you can get away with less ( but a stock cam combo would out perform it in a 0-60 test )you need to have a goal in what you want, the down side to all to this is Cost any higher than stock stall converter for a 144-200 engine would be a custom unit ,( they are unique in that the bolt pattern and ring gear combo makes them unpopular) , the 250 guys can buy one for a V-8 Ford 289-302 as an example but for a 200 prepared to pay 500.00-800.00 for such an Item
What cam would you sudjest? I was looking for 150-175 horsepower a weekend car local shows etc not sure what way to go looking for as much power that i can get with what i have to work with have about 3000.00 to spend will have custom inline do my head work headers dui ignition etc any sudjestion needed thanks
For that Hp level , you want as much compression as pump gas will allow , so shoot for about 10-10.5-1 I am not a fan of the DUI , it has its good points , but for the money a Recurved Duraspark with a MSD 6al box will out perform and cost less , port the head and add larger valves , an adjustable valve train and a Solid cam , the one that is in my 250 would work great unfortunatly is a Crane unit that is no longer made , CI has some that will work and I strongly say to use a Solid Grind , NOT a Hyd , its free torque an hp ( and no you don't have too constantly adjust the valves with today metalurgy) ( as much as your budget allows a direct mount 2brl a 350 Holley is what I would suggest , with the Bowel facing the valve cover , yes you will need to fab a cable throttle , again a High stall converter will be needed , unless you only want a sound and looks combo as compared to one that performs as well as it sounds and looks , a Manual Valve Body in your Trans will eliminate the need for a Vacuum modulator and a kick down and the Factory shifter can be modified to work slick ( if you go that route I can fill you in ) rear gears shoud be in the 3.5-3.80 range for , Headers and a good dual system is a must , I think to have the total package will be in the 5000.00 dollar range but you could build the engine and add the externals as money allows
