I have a 64' Fairlane with the original 200 six... but I have some questions.
1) How much compression should I run with 10 pounds of boost?
2) Can I use the Turbo off of an early Cummins "B" Model engine (The one used in Dodge Rams,) as long as I put a "softer" spring in the waste gate?
3) What is the best turbo I can get for the engine, without having a lot of lag off the line?
4) If I am getting this correctly, can I run a J-pipe to the turbo, run the suction side of the turbo through an aftercooler, then right to the carburetor?
5) Is a 350 Holley 2 bbl sufficient to feed the engine, or should I get the bigger 500 CFM?
6) How much horsepower can I expect to make at the crank with this set up?
7) Is the comp cams 260H a good choice for the 200
8) Where can I buy one of those carburetor hats, or do I have to custom make one?
9) Whats the fuel economy going to be like with this engine?
Sorry about all of the questions...
