DS2.echo1955":ixnje5ry said:After reading all I could I have decided on the DUI ignition. Everything sounds good except the price..![]()
JackFish":3dve61hr said:DS2.echo1955":3dve61hr said:After reading all I could I have decided on the DUI ignition. Everything sounds good except the price..![]()
echo1955":qzwfsbtl said:When I finish my Mustang my granddaughter has a 64 Falcon w/170ci in it.
She hasn’t said anything yet but…. proly be me next adventure.. :mrgreen:
echo1955":37n7194l said:Hey Freddy I found the cam.. now all I need do is understand it…
Isky #321256 cam (degreed in straight up)
FORD 6 CYL 321256 256 Supercam .450 256° 112° 392-HY
echo1955":1ox3xmkv said:What does this mean?
Balanced rot/recip assembly
rocklord":3nthnjas said:echo1955":3nthnjas said:When I finish my Mustang my granddaughter has a 64 Falcon w/170ci in it.
Be aware that the 64 170ci has four main bearings, not seven as found in your 65 200ci.
As for oil, you may want to look at Rotella. Dino oil that still has the ZDDP needed for our six.
MPGmustang":14ac6ej2 said:echo1955":14ac6ej2 said:Hey Freddy I found the cam.. now all I need do is understand it…
256* @ .450 (.050 it's 112*)
IIRC it's lift is at 256 degrees, and lifts .450 max with stock rocker ratio (1.5) the 112 is the lobe separation, closer together the more it's ment for low end torque, 108*-112* are your options
IMHO for your build stick to torque, shoot for a nice 262/264 duration cam with 108 lobe centers, and advance it 6* (4* for the initial advance @ .050 and 2* more to lower the torque curve operating range) this should give peak torque around 1000-5000 nice for stop and go.
BUT if retaining the C4 auto, stick with the 112 lobe, it will give a better idle. and probably stick to the normal 4* (or .050) timing advance on the cam
The DUI price is more convenient as you know you can't miss anything or forget anything. but the price of 100 bucks can go somewhere else if needed. either way, it's a chunk of change, and the DUI more than pay's for itself IMO on setup time.
GL and Have Fun!!
Richard
rbohm
this means that the crankshaft, rods, and pistons were properly balanced. what happens is the pistons are weighed, and then weight is taken off the heaviest pistons until they match the weight of the lightest piston, with in a gram or two.
then the connecting rods are also weighed, first a total weight, then each end is weighed, and again the heaviest rods are machined until they match the lightest rod, again within a gram or two. and this means both in total weight and each end.
then the rod, piston, ring pack, and rod bearings for one cylinder are weighed, and a weight equal to that amount is attached to the crankshaft at each rod journal, and the crank is spun to find where the balance is off. then weight is either added or subtracted as needed from the counterweights. rather like balancing a tire on a dynamic balancer.
rbohm
1: the .450 is the net valve lift with the stock rocker arms
2: the 256 is the advertised duration, usually measured at 0-.006" lift depending on the manufacturer.
3: the 112 degrees is the lobe separation angle. the wider the angle the more dynamic compression you have, the better your low end torque. be careful when using this to help tune an engine combination, because if your static compression ratio is too high, you can very easily run into low speed detonation issues due to too high a dynamic compression ratio.
4: for this lobe separation angle i would keep my static compression ratio around 9.5:1 for best results.
how can I determine static compression
JackFish":3qld8cdc said:I'm not sure if you mentioned what transmission you have, but a 112LC is recommended for an automatic.
I don't think balancing a reciprocating assembly is worth the expense unless you're building a race, or heavy-duty work engine.
bubba22349":34tb9u1d said:how can I determine static compression
1: Static compression is the total volume of the cylinder (bore dia, by the stroke length) compressed into the Head chamber volume (or CC’s),
2: plus head gasket volume (at its compressed thickness), the pistons deck height i.e. (zero deck has no effect)
3: if its below deck then its added to chamber vol. if its out the top its minus, and also add if the piston has a dish volume.
CZLN6":2y93mso5 said:Howdy Echo and All:
"My bore is 30 over (3.68+.30=3.98 ??)"
The "30" in this case refers to a .030" overbore. So your new bore size will be 3.71".
While balancing a street engine may not be necessary, I would always go the expense. It makes for a smoother, longer lasting engine and increases my peace of mind.
I love the Falcon. It could be the ultimate sleeper bird. I love the stealthy, sleeper ride.
I sure have been enjoying your journey. Thanks for sharing.
http://classicinlines.com/SelectCam.aspClassicInlines":2diuu3fp said:Simply put, the lobe center of a cam controls where the power curve is applied. The tighter the lobe center, the lower the rpm range; the wider the lobe center, the higher the rpm range. The rpm range is also known as, or refer to as the power band. In general, two degrees of lobe center is equal to approximately 500rpm. Therefore, if a cam with a 110* lobe center has a power range between 2500-6000 RPM, the same cam with a 112* lobe center would have a power range of 3000-6500 RPM. Conversely the same cam with a 108* lobe center would have a power range of 2000-5500 RPM.
JackFish":i4fyqghh said:I'll be honest, I've never priced balancing an engine, except to see that V8s start at about $250 or so.
At that price, if you can afford it, it's certainly worth it, and if you can do some of it yourself, even better.
But engines never come balanced from the factory and they do last a long time under normal driving conditions and regular maintenance.
MPGmustang":3imamiw4 said:I love good reads...
ClassicInlines":3imamiw4 said:Simply put, the lobe center of a cam controls where the power curve is applied. The tighter the lobe center, the lower the rpm range; the wider the lobe center, the higher the rpm range. The rpm range is also known as, or refer to as the power band. In general, two degrees of lobe center is equal to approximately 500rpm. Therefore, if a cam with a 110* lobe center has a power range between 2500-6000 RPM, the same cam with a 112* lobe center would have a power range of 3000-6500 RPM. Conversely the same cam with a 108* lobe center would have a power range of 2000-5500 RPM.
I hate to confess this but I have read all of those teck articles several tines over.
The only 2 places where I stumble are with determining the compression even though the formula is clearly visible. I will just have to wait until I get my block back on that..
And
Cam selection with me wanting to keep my current rear-end and trans…
If I was going to change the RE and Trans I would have no problem with cam selection…
The question is ,
What RPM do you want the most/peak power (HP/Tq) at?
low 1000-2500
mid 1500-3000
high 2000-4000
With the CI alum head I woudn't worry about higher rpm's (2500-5500) as you'll get that naturally, but as your staying stock tranny, rear, and probably tires. your cruise rpm is at ~2500 to 2800 rpm @ 65mph so I would look for a mid range say 1000-4500rpm for decent acceleration and great power at driving
