Well The winter project has come together. Here is the run down
"8 inch rear out of a Maverick. Four Lug. Geared to 3.25
Rebuilt T-5 out of a turbo coupe
Engine.
Late model block.
0.30 bore. 0.10 under crank main and rods. Block was decked 0.20 rotating mass balanced. ARP rod bolts. New FSPP balancer, dual timing gear and chain and a ARC-268/274 (110*) Hydraulic Dual Pattern cam
The head is a late model head. cc to 52 new valves and heaver springs
Holley 5200 carb. Still working on jetting and power valve but pretty close.
Ignition. New Mallory dual point centrifugal advance tied into a Mallory Hifire ignition system.
Now the problem. Every time I put the pedal to the floor the rear wheels break loose never did this before
Engine.
Late model block.
