I am new to this site but it really appears to be just what I am in need of.
I recently completed a total stock restoration of my 64 1/2 Mustang coupe including a total stock rebuild of the original 170, only aftermarket piece being Pertronix electronic conversion of stock distributor. Everything worked like a champ.
Make a long story short, a good friend of mine approached me and asked me if I would help him do a ground up resto on his 68 Mustang coupe. We rebuilt his original 200" 6, punched it .030 over, and installed a Hooker 6/2 header with 2 1/2 " dual exhaust and again, the Pertronix conversion. Carb and distributor were replaced with reman. units from local parts store. So far, so good, right? Well, now it seems that no matter what I do as far as initial, total timing, We have a slight intermittent ping under light to moderate throttle. The only way I seem to be able to "time" it out is to back off my initial to about -2, at which point the engine idles and performs about as well as my Farmall B tractor. I did repair a small crack in the intake right behind the carb. I have 20" man. vacuum and do not seem to have an intake leak. At this point I am beginning to think that the install of the header is creating a lean condition or, possibly even worse that the crack in my intake extended into the "roof" of the middle two exhaust ports and is causing my problem. It has me truly stumped. I have been working on Mustangs and other Fords for years and have run into some wierd stuff, but this one is starting to get the best of me. Thank you in advance to anyone who may be able to point me in the right direction.
Thank You,
Phil
Thank You,
Phil
