Hi, as mentioned, the older voltage regulators have mechanical contacts that open and close to regulate the current in the charging system. Later on, I don't remember, but it must have been in the 1970's, Fords came with an electronic voltage regulator that is practically bullet proof. The electronic regulator is a direct bolt in, with the same plug, and many guys will just use the newer regulator on the older cars. Good luck
