6bangerwanab
ok im not sure if i know enough about the cooling that is inside the block, but how possible is it to make the cooling system flows backwards? it would take some strange fabbing to get the hoses ran right, even if a crossflow radiator. and the thermostat would need to be relocated appropriatly. and the pump would need to be modified to pump backwards and possibly run backwards. the whole point is to get the cooler coolant to the heads first.
