Junior64
I have a '64 Falcon with a 170. I have a rough idle while in park or just sitting at a light. I have an automatic transmission and set the RPM at the factory 525-550 setting and it shakes quite a bit and put puts out the tailpipe. Nothing fixes this except when I give it gas or increase the idle RPM above 700. Below is a list of work I have just completed on it.
- Resurface Head/Complete valve job (valves, springs, guides, seals, seats)
- New lifters and push-rods (hydraulic)
- New plugs
- New wires
- New coil
- New distributor cap, rotor, points, and condenser.
- Timing checked (Does not fluctuate at idle)
- New fuel filter
- Re-built/adjusted carburetor
I did notice some wear on the distributor gear when I pulled it out, which makes me think that may be causing it. I am just hoping that someone out there has experienced the same issue and can point me in the right direction. Right now I am thinking about getting a re-manufactured distributor and then maybe checking the timing chain if that doesn't work. The engine doesn't make any abnormal noises, just shakes a bit. Please help!
- New plugs
- New wires
- New coil
- New fuel filter
