It's rough and missing at idle, cold or hot, less so when cold. OK at cruise.
No valve train chatter to speak of.
I've:
Swapped the coil, plugs, wires, and cap.
Took the carb off and cleaned it thoroughly. It was missing the check ball and weight, but their addition has not solved the problem. And set the float.
Isolated EGR vacuum, it's steady, and the manifold vacuum seems to function OK. It was steady around 6-7, dropped to 0 opening the throttle and up to 15 at high rpm, then dropping back down.
Compression came in @ 166, 170, 174, 174, 164 ,160.
Swapped the PCV valve.
I ordered a new three port PVS and have to check the vacuum on that some more, but I am wondering if the problem could be the old alternator and if it could cause the rough idle before I pull it and take it in to be checked.
There is also a crack in the exhaust manifold close to the choke port.
I've:
