See my previous thread about pushrods. As it turns out, the pushrods looked fine, and the valve stems and springs looked fine. Driveability was terrible, but increasing timing and idle speed was enough for me to be able to go the short distance to work. The problem started when taking a short 2-mile freeway trip with a badly leaking water pump. Temp never maxed out, but clearly I lost about 3/4 gallon of coolant.
Yesterday, I put a can of STP motor treatment 1/2 in the gas tank and 1/2 in the crank case to hopefully clean things up inside. My trip home from work things seemed smoother. This morning, I warmed it up, sprayed the remainder of a can of carb cleaner into the throttle bore as I was revving the engine, then did the old seafoam treatment. Things seem much better now, but idle is still rough, and low speed is still a bit sluggish.
Thoughts here? Drive for a few days and see? Perhaps a carb rebuild? My thoughts are that I somehow gunked up or had a valve stick partially open or a lifter get clogged up, and the seafoam and the other solvents have partially solved that.
