I have a '76 Maverick and has a 200 in-line 6 engine. I purchased it at the beginning of the year, it came from Alabama and it's only got 14,000 miles on it. The car was running very rich and sometimes stalling. I pulled the carburetor (a Carter, model YFA carburetor) and had a mechanic install a carb kit. It ran much better, but was still not quite right. I drove the car to the same mechanic to have him fine tune the carb and check the timing. When I picked the car up, he said that he has worked on many of these I-6 engines and they never run completely "smooth". After the adjustment, the car seems to run well at highway speeds, but it idles a bit rough, and when I come to a stop sign, it almost seems like it's going to stall. I had a couple of friends (who know more about engines than I do) listen to it, and they said that it sounded like it was starving for gas when idling. One guy said that he thought perhaps one of the ports may be partially blocked, and the mechanic may not have cleaned/soaked the carb good enough when installing the carb kit.
1.) First, it is a common characteristic that the straight 6 engines idle a bit rough?
2.) Any suggestions as to what I should be checking for? Could the problem be a sloppy carb kit install?
