Hey guys, thanks for all the help with my earlier post with the shaking problem on my 66 200ci, it turned out to be a loose fitting valve and valve guide on the number 4 cylinder. It was sticking, causing the cylinder not to fire, and also causing the engine to shake alot while idling and accelerating.
While we were at it, we replaced the number 4 head and rings because they werent holding enough compression....now the engine runs and idles MUCH smoother.
After doing all of that, the engine seems to be running hotter. WHile driving around town it gets up around the half way mark, when it used to only get around 1/4. When driving on the highway around 65 it gets pretty close to the end of the normal range mark( pretty close to the H).
Could this be because of a timing problem? Or maybe the thermostat? Im pretty sure that one of these is the problem. The guy that put the new valves and head on said it was the timing.
How much is a timing gun cost? And what are the symptoms of a thermostat that has been put in backwards?
Thanks for all the help guys!
