mustang652
Need some help. Due to some major health problems and a continuing series of problems over the past year trying to get an Offy 3X1 system running, I've decided to scrap the project. Since I've already done the 264/272 cam pkg and Dizzy II, I'd still like to have better carburation and performance. I've got a couple of spare round/small log heads that I can have milled for the larger valves and better compression. The one I was using when I started the 3X1 project and an NOS one that has never been built up and used. I'd need to go with as simplle a bolt on application as possible. I've priced out a Weber 32/36 at $249 and looked at the various adapter. First and foremost, is ths a reasonable idea and will it require hood mods, and which is currently the best and most simple adapter to use. Mike has his listed as out of stock, I have found one at Clifford, two at Summitt (not sure which to use on small log head), and one on the Weber site.
