CNC-Dude":2ssgbgiq said:I draw a CAD file for CoupeBoy a while back that was an adapter to bolt a SBF bellhousing to a small 6 bellhousing. I'll see if I can find it. But yes it would be much easier to draw and dimension one from an existing plate.
If you ever find the CAD file for the adapter, could you email it to me also.
Chad now your likely going to have a problem with the 250 bell housing that you got with your engine its likely going to be the small size bell (a Car type) for a 157 tooth flywheel (since the 250's were never offered in a truck application) I am betting the 300 / 4.9 truck flywheel you bought is also going to be the 164 tooth and that won't work with car type bell. So you will need to use a truck bell housing and block plate with that flywheel or flex plate (which ever it is) like using all the parts from the same engine you got the flywheel from so that its all going to fit together. Good luck
x2 yes I think that would probably work good but it could take lots of time though.
