OK here's an update on the manifolds form Lynx for the Stromberg and Dellorto/Weber side drafts for both the log heads and the 250 2V owners.  The good news is for the log head owners interested in side draft carbs.  I assume this manifold works like the Offenhouser set-up but for side draft carbs, either Strombergs or Dellorto/Webers (high coolness factor).  Lynx has about a dozen of each in stock (see below).  The 250 2V manifolds are out of stock and will require a 20 unit minimum purchase.  In either case Lynx is recommending that we combine our orders and work through their US distributor to get the maximum savings on freight.  So here’s the question: Who is interested in placing an order for a side draft manifold?  Is a group buy possible?
This is the message I received from Brad at Lynx:
Regarding the manifold part numbers, here is the stock situation at Lynx, AU:
M 058 – 11 in stock, (this is the log head manifold for 3 Dellorto/Webers list Price: AU $383.24 US $222.27)
M 060 – 12 in stock, (this is the log head manifold for 3 SUs list price AU $371.69 US $215.57)
M 189 – nil, (this is the 2V head manifold for 3 SUs list price AU $350.68 US $203.39)
M 190 – nil, (this is the 2V head manifold for 3 Dellorto/Webers list Price: AU $361.02 US $209.39)
Due to economies of scale, we need a minimum of 20 of each number before we will remake them. We could make just one, but the price would be the same as 20. Don, can you look at getting an order together from other club members to try to come up with numbers that make the exercise feasible? For convenience, I would suggest that you liaise with Paul Simoes in the US in this regard.
