It's pretty easy to know that you have too little lifter preload, you would be hearing a lifter or lifters ticking on a cold start up and or even while its running at higher RPM's.
If you happen to set the lifters with too much preload or even bottom out the lifters internal piston which is a very common occurrence for first time engine builders, until you develop the feel when your ar a Zero Lash. The valves are then being held slightly open off the valve seat so the engine might be very hard to get started if at all, popping out the exhaust or the carburetor, and or if it dose run it could be running really rough or uneven. If you did a Hot lash with Zero and then 1 turn was this with the engine running? Good luck
